11-08-2022, 09:57 AM
Austin BT12 spanner
11-08-2022, 10:00 AM
Yes it would, but he wanted something that looked correct until he could find an original BT12.
11-08-2022, 10:01 AM
Is this for display purposes only?
11-08-2022, 10:16 AM
(This post was last modified: 11-08-2022, 10:17 AM by Marcus Ling.)
In case anyone is interested there is a guy here in New Zealand who has been making a similar tool for MGs from the 1930s. The price each in 2016 was £68 plus £7.50 postage to the UK.
MG Spanner.jpeg (Size: 58.27 KB / Downloads: 108) He is more interested in a tool that he can use.
11-08-2022, 10:24 AM
Is it simply for display purposes, Marcus?
The original ones I have used are dreadful, nowhere near meaty enough. I ask, because if you are going to go to the trouble of making new, I would ensure they are thicker than the original ones, even better would be forged.
11-08-2022, 10:31 AM
He wants a tool that he can use. Are your original ones pressed out of flat steel ? if so what thickness is the material ?
Cheers Marcus
11-08-2022, 10:35 AM
They appeared to be, but I gave them away years ago, Marcus. They were utterly useless.
I have a super spanner for the job, I will look it out and post a photo of it - works perfectly.
11-08-2022, 10:39 AM
Thanks Ruairidh,
Do you only use one spanner or a pair? one to hold the tappet and the other to tighten the cone lock nut ? I'm away from home at the moment so I cant measure the size of the tappet/locknut could you please let me know the sizes. Cheers Marcus
11-08-2022, 10:58 AM
11-08-2022, 11:13 AM
Thanks Ruairidh,
Those photos are perfect. I will get a few cut in different thickness material and let you know how well they work. Cheers Marcus |
