Austin BT12 spanner
Hi,
I am hoping that someone who has an original BT12 tappet spanner could post a photo with dimensions as I have been trying to find an original but without any luck and now want to make a replica until I can find an original.
Any help much appreciated.
Marcus
Is the one you want details of single or double ended ?
Hi Pete,
Thank for the reply, I didn't realise there was a double ended BT12. The one I am after is single ended as per the picture from the Parts List.
.jpg   BT12.JPG (Size: 9.36 KB / Downloads: 477)
Marcus
I rather thought that was the one you are looking for. Me too !
I imagine you have an early Seven to want the single ended version ?
PeteUU
Well I've learnt something new.
Yes there is a double ended version which seems to replace the single ended one at the introduction of the coil engine.
I have one I think. I'll check in a bit
I have one of the right size and shape but it's marked AH67
Hi Joe,
If its the same would you mind posting a photo with the dimensions please.
Thanks
Marcus
Here it is on mm square graph paper. If it's the right thingĀ I'll do a drawing later if I get a chance
Thanks Joe,
That's perfect I can measure it off the graph paper.
Marcus
