Valve Chest Oil Seal
How does one seal the valve chest on an early block (with screw in core plugs) when there is only a very small land along the upper edge?
(Yesterday, 04:55 PM)Martin Baker Wrote: How does one seal the valve chest on an early block (with screw in core plugs) when there is only a very small land along the upper edge?
I'm using a section cut from a silicon baking tray (from Dunelm).
Seals well enough to pass scrutineering
