03-03-2018, 04:04 PM
Does anyone know a source for the small 6 amp field coil fuse or suitable automotive 6 amp fuse wire for the CFR2 Voltage regulator?
CFR2 Field Coil Fuse
04-03-2018, 12:10 PM
The correct short 6 amp fuses seem to be like hens teeth, there are plenty 10 amp ones around but I don't like exceeding the makers rating so I use domestic plug 5 amp ones which are the correct length. Now I suppose there will be screams of horror at this.
04-03-2018, 01:48 PM
I use a 5 amp glass fuse that I bought at the local car electrician here in Fribourg, Switzerland.
If the fuse is good for 240v I think it's OK for 6 or 12v. I read somewhere that the other way round can be dangerous since arcingĀ may occur when the fuse blows. Steve |
