Which Gasket Sealant?
For many years I used Hylomar Blue which I found easy to apply and effective.
Last year my old tube finally ran out so I bought some new but this seems to be much more viscous and I can't obtain a thin, smooth even coverage as it goes on rather like silicone bathroom sealant.
Was I unlucky or has the formulation changed over the years.
What would you recommend?
John.
Threebond 1215
What Charles said!
Sheesh! Over £17 a tube?! I must be getting old...
But it doesn't go off in the tube and so a tube will last you for years. Mine has.
Did you leave it long enough for the solvents to evaporate. As apprentices we were taught to massage it with a rounded wooden dowel to help. And it wasnt a wind up it was in the company handbook.
Pretty close to ooh matron there, Andy!
Smile
I use Stag Wellseal; developed by Rolls Royce.  It also doesn't go off.
It used  to be called KMC Wellseal  - I still have some - but it's the same stuff.
Relatively reasonable at £14 a tube.
I thought this was discussed fairly recently — a thin coating of  Locktite 5920 RTV Copper Silicone seemed to find favor with many. I subsequently bought some and used it to very good effect.
I always use a thin smear of grease on gaskets. Very economical.
