Zenith 26VA carburettor
Good evening all.
I'm looking for a little assistance. I'm currently trying to repair a side draught zenith 26VA carburettor, having discovered that a few parts are broken.
I'm looking for an accelerator lever to fit to the butterfly spindle, and an air screw.
I'm actually trying to finish a car prior to having it assessed. The owner passed away earlier this year.
Many thanks, Mike.
.... The car is basically complete, we discovered the carburettor had been removed and had to try a bit of common sense investigating. I've had a look inside the inlet manifold and combustion chambers with a bore scope, in case parts of the spindle were in there. We just need to get the engine started for the assessor.
Give Tony Betts a call at County Austin’s 01162867522
