6 volt electric cooling fan
Hi All
I’m currently running the special without the fan belt and haven’t had any overheating problems.  In truth the fan wouldn’t be much use as it’s a good 2” away from the face of the core  Big Grin.
However mindful of a hot summer and some steep hills in my itinerary I’m wondering about fitting an electric fan.  Trouble is most seem to be 12 volt and taking 80 to 180 Watt.  My car is 6 volt.  Has anyone used a 12 volt fan at 6 volts and is the drop in fan speed significant when cooling the A7?
Before anyone asks the rad core is new, engine waterways fully clear etc etc.
Spacer,  and 2 bladed fan
Spacer, and 4 bladed fan
Spacer, 4 bladed fan, leave the bonnet off if it is a really hot day.
Are what I would try before "modern" stuff.
2 or 4 of these mounted immediately behind the rad core should do the trick without caning the dynamo/battery
https://www.ebay.co.uk/itm/165190817665?...Swg1phl1uC
No need to take the bonnet off, you just need a couple of rubber bonnet wedges under the rear edge of the bonnet which were very common 70 years ago.
I got one like this (https://www.ebay.co.uk/itm/384698370617?...%3A2047675)
works a treat when combined with an in line thermostat relay like this one (https://www.ebay.com/itm/173644226248). also available in 32 millimeters .
Mind you: fitted to the front of the radiator of my Rosengart LR4N2 behind that 'fencing mask' radiator shroud.. An A7 might demand deleting the standard fan.
Hi All
Thanks for all the comments.
I did make up a spacer but when added to a long early coil fan housing it looked a bit strange.
I’ve ordered a couple of computer fans and will devise a mounting that is unobtrusive.
Once again thanks
Hi All
Once again thanks
