Resin tank lining
Can anybody recommend how to remove failing resin coating from a petrol tank. Thanks
Cut a hole large enough to get your hand/arm in and pull the stuff out!
When finished solder a brass patch over the hole.
https://www.austinsevenfriends.co.uk/for...h#pid39977
Frosts do a stripper solvent which works!
I think I used acetone when the sealant failed on my car.
Thanks very much for your responses
