SPLIT PIN HYDRAULIC SHOE HOLD DOWN
If you are retaining the beehive spring and split pin method of holding the shoes against the backplates I would advise not using stainless split pins.  I struggled to get a 1/8th inch pin to open out adequately to hold the spring/shoe tight against the backplate, even with spring clamped down.  Changed to a mild steel one and easily succeeded.
Intend to change to using Girling method with Ford 100E 1200 pins/springs/washers in future........must make progress at moment if going to get to Centenary week.
Dennis
