Car type: Austin 7s
Can anyone confirm the thickness of an original 1 5/16” flywheel nut?
I only have a new one to hand and it’s snagging the recess in the clutch centre.
Thanks.
Henry this is not unusual dome the top of the nut and don't use a lockwasher use locktite. Terry.
I totally agree with the answers above.
+1. Usually found I've had to do the same when using a new nut.
