Hello all,
Slowly progressing with the chummy project and getting to the point of the wings and headlight mountings. I've had a look at various pictures but can't quite see how the headlights attach, or at least there seems to be a bit of variety which may or may not be how they left the factory.
Can anyone advise on how the headlights 'should' attach, along with how the wiring should be routed (again seems to be different approaches!). Close up pictures would be much appreciated!
Many thanks in advance
Thanks for those Hedd, it's '29 AE type, so I'd think similar to the first picture. I'd overlooked that some AD's had wing mounted lights as well. Thank you for the offer of further pictures, no urgency but much appreciated when you have a moment.
Hedd
I am interested in the differences, but I can't see any headlamps or brackets on your first image.
robert, the brackets are fitted in the first pic.
Thanks Hedd, I can see them now.
Many thanks for that Hedd. I'll see if I locate some ready to go in the first instance, otherwise I might take up your kind offer of measurements - if anyone has some going spare please do get in touch!
Should the wiring go through a hole in the wing, or can it be routed from the from? I think I've seen both, and only one of my wings has a hole in place for the wiring.
They were fitted with R47 lucas lamps. I've never seen one where the wiring doesnt go up the spout.
Infact theres a pair in the photo above.
