04-01-2021, 06:03 PM
Starting Handle
04-01-2021, 06:29 PM
Looks like a home made conversion from a long nose to a short nose - 'O' rings didn't exist in 1930 ?? There should be a coil spring which bears against a shoulder on the inner end of the nose and bears against the "hub" of the starting handle. I assume that the start handle boss does not pass through the bush (with the O ring) which it should do so the spring retracts the starting handle. But I could have got it all wrong !!
04-01-2021, 10:01 PM
It should probably look like this (1929-30 pattern), with the handle shaft retained by the brass nut (the nosepiece is threaded to suit).
The later, peg type started in March 1931. DSC_0941ss.JPG (Size: 48.58 KB / Downloads: 207)
04-01-2021, 10:48 PM
Hi Mopetta
http://www.austin7.org/Austin%20Seven%20...20Handles/ This is what you should have! Cheers Howard
04-01-2021, 11:20 PM
Well done Howard, good link. No parts available for this type, I convert them to take the later shaft as per yours on the Brookfield
Best Wishes Gene |
