Spade ends ht
I'm making up new ht leads,  solder the little hole on the spade end or not ?
Yes because they don't work very well if you crimp them.
Cheers,
Dave.
I do
(and those are words I think twice before uttering).
"I am" is apparently the shortest complete sentence in the English language
"I do" is definitely the longest sentence... Angel
Aye
Greig
I have done
(Just to be different.)
I also use heat shrink cable wrap as it supports the cable and helps prevent vibration fatigue on the copper core.
I never have done and never had any issues.
  I use a spade bit to open up the hole  and push the cable right up to the plug hole. Then crimp in a smooth jaw vice.
Always
This was laboured recently. Solder tends to wick up the wires making these rigid and prone to fail esp with manual advance. (Solder should not be used for wires retained by grubscrews as the solder creeps and the screw loosens)
Spade lugs look nicely original (I soldered but used the very minimum)
The hole filling with solder lets you see the solder has wetted inside nicely.
Search using 'spade end plug leads' as the search term MM. There's even a couple of pics on that thread.
