22-04-2020, 12:24 PM
(This post was last modified: 22-04-2020, 12:34 PM by David Witton.)
Trying to source diff bearings for 32 axle. Existing ones are SKF marked “W6536” and seemingly unavailable.
Does anyone know of the modern equivalent RHP please?
Thanks in advance
Ignore previous. It has been resolved.
22-04-2020, 02:07 PM
(This post was last modified: 22-04-2020, 02:09 PM by Nick Turley.)
I think the ones you are wanting in RHP are LJT 1 1/4M
LJT 1 1/4 indeed. Have you tried Jamie at Seven Workshop?
Thanks chaps. Already on the case. Stay safe
Thank you Tony. I had a similar problem a few years ago and recalled your comments on the wider bearings at that time but couldn’t remember the equivalent RHP. Eventually found the original thread on the old forum. New bearings available from cherished supplier.
