The horrors that lay within...
The cause!
Nothing wrong with that I can see Ruairidh... wind the torque tube out a bit?
Looks a bit like one I got fro southern sevens. Told it was a good un... good for what I never did discover.
Ouch!
Crikey! Looks like something has come adrift inside the case to do that, did you find anything?
It was almost certainly caused by something that is incorrect in the second photo Ivor.
Mmmh, the locking tabs haven’t been turned over, but the nuts are still there...This could be a two pipe problem or I’m being a complete twit...
The thrust bearings have been installed the incorrect way around.
Ah, now you mention it! I’ll get back in the workshop and do something constructive thanks Ruairidh!
What does the pinion gear look like Ruairidh?
