Switch securing
Hi people
Anyone got a securing “spring” for a Ruby ignition/lighting switch?
Or any suggestions on how to.
           Tim
Ps To fix the switch to the dash panel
You could wind your own. Get some 16 SWG wire from a model shop and wind it around a wooden former. You would need to experiment a bit to find a former the right size, probably 2/3 the diameter of the switch body. From memory, you would need about 5 turns.
A suitable jubilee clip will work if you are stuck.
Or buy a whole new unit: https://www.theaustinsevenworkshop.com/p...ning-light
Was it this one you are after for the Lucas PLC switch?
Photo is from Paul Beck Vintage Supplies who sell them LINK
[Image: 836C-1__3000001__.jpg]
Thanks Timothy that’s exactly what I need.
Tim J
