05-01-2019, 08:07 PM
(This post was last modified: 05-01-2019, 08:10 PM by Tony Betts.)
Christmas just a little late today.
Had a delivery of 4 cranks and 10 sets of rods.
Bee waiting for over three years for these.
And this time I GET TO KEEP ONE.
[attachment=4993]
This is the main ingredient for my idea of a very fast perfect engine.
Mine is number 10 from the batch.
[attachment=4994]
And this is it.
A fully counterbalanced HADLEY crank.
[attachment=4995]
And matching set of HADLEY rods.
[attachment=4996]
Nice one Tony - what will it go in?
Lovely Tony.
The premium Austin 7 crankshaft solution!
Charles
HI Tony,
Would recommend the Rods they are TOP END well finished and perfectly Balanced
and happy to enlarge small end to 15mm for me
Colin
NZ
A dream to fit, I agree Colin, top notch.
Hi R,
I travel the usa every year.
But it's always been a dream to take say 4 months in a camper with a seven on the back to take in as much as I can. Across the states coast to coast.
Including the bonnaville salt flats. Hopefully registering a seven for a run.
What I'll put the engine in? I'm not quite sure. Something I already have. Or even, I have an idea for a special, and even some parts ive saved up?
And Colin, I'm glad you like the rods.
I'm happy to be able to say I had quite a bit of input in the rods being made, along with two other. Peter Pearson, and Tony white.
There is more to them, than anyone would realise.
Tony.
Sounds right up my street Tony - are these the same design rods as your previous Hadley ones? Those were a dream to fit.
Hi R,
Exactly the same.
Usually I only get the rods done at the same time as the counterbalanced cranks.
So the rods are out of stock for large periods of time. Well years at a time.
They are not cheap to have made, sadly very little profit for me as a business.
I used to do the same rod and a standard crank in an 1 5/16 as the kiddy crank and rods. But the cranks are expensive and massively slow to get made. The rods were also not cheap, but did come in a lot quicker. In short a lot of bother for little gain.
Tony.
