Car type: Ruby mk 2
I am sure you are fed up with this question but what’s the best method to achieve a
Seal on the Ruby sump.
Bearing in mind removal for oil change.
Tim
Zeto is there a part number for that gasket from Seven Workshop? It isn't listed on their online catalog.
Stephen
How many times do you take your sump off ? With modern oils and regular changes, I would remove and clean the gauze perhaps every 50,000 miles.
Car type: Ruby mk 2
So no need to clean the filter ?
Only after high mileage
