Camshaft bush
I need to modify the camshaft bush securing bolt.
I see the recommended method of drilling and tapping but is it possible or advisable
to do this without removing the shaft ?
            Tim
(3 bearing Ruby engine)
(15-10-2018, 03:30 PM)Tiger Wrote: I need to modify the camshaft bush securing bolt.
            Tim
In a word NO!
J
Whilst doing this with the camshaft out it is also a good idea to check the camshaft end float and adjust if necessary. Quite an easy job with the cam out.
John Mason
