06-09-2018, 06:01 PM
Hi , Does anyone out there know if the RP originally had a rear blind.? If so does anyone know where I can purchase one.
Rear Blind for 1932 RP
06-09-2018, 06:31 PM
Mine certainly had the fittings when I got it.
06-09-2018, 07:06 PM
06-09-2018, 08:03 PM
This may help you http://www.austin7.org/Technical%20Artic...r%20Blind/
06-09-2018, 08:18 PM
(06-09-2018, 08:03 PM)Biddlecombe Wrote: This may help you http://www.austin7.org/Technical%20Artic...r%20Blind/ Thank you Biddlecombe, A good article. Not sure that I could make one but if one became available then I would probably go for it. Cheers Smiley
06-09-2018, 08:58 PM
The one in the article looks to be a copy of one from a ruby, probably fitted in an RK or box.
I probably shouldn't say this but I started making a batch of box and Ruby blinds around 7 years ago. Never finished them. So have a pile of bits on the shelf. Didn't get time to finish them then, and have no more time now? Tony.
06-09-2018, 09:49 PM
(06-09-2018, 08:58 PM)Tony Betts Wrote: The one in the article looks to be a copy of one from a ruby, probably fitted in an RK or box. Hi Tony, Did you make all the bits for an RP Box. If you have a "set".I would be happy to purchase from you and make them up myself.
06-09-2018, 10:48 PM
Mine had little roller blind brackets on the rear window surround, not the Roman type blind in the article.
07-09-2018, 08:17 AM
I'm happy to be corrected but I thought Box Saloons always had roller blinds and Rubies had the drop-down type in the article.
I was considering making the Ruby ones - but now I know Tony has got a 7-year head start on me perhaps I won't ![]() Peter.
07-09-2018, 08:22 AM
Lots of good info and pictures here: http://pub25.bravenet.com/forum/static/s...1&cmd=show
