DJ-4 and DJ-4A
In reading about these distributors, I've found references to both a DJ-4 and a DJ-4A. Can anyone enlighten me as to the difference? Is one clockwise and the other anti clockwise?
Erich in Seattle
Hi Erich,
From my assumptions, so I'm probably wrong,  3/4A dizzies simply have side exiting plug lead caps. Not normally found on Sevens but are an alternative if required, and I have seen a picture of one fitted to a Seven from the good old days when if it fits - that will do nicely.
Peter
I believe the A stands for auto advance...
http://www.da7c.co.uk/technical_torque_a...nce_di.htm
but as always stand to be corrected.  Smile
