14-02-2024, 11:26 AM
Rist Horns
14-02-2024, 10:55 PM
Thanks Gents for taking the time to clarify the Rist horn usage. My conclusion from reading all of your advice and attachments is that sometime during the Ruby production Austin started fitting Altette horns instead of Rist Horns.
When I bought my Ruby it had a faulty horn that resembled the photo above. I exchanged it for another horn (which is definitely not an Altette) that now is faulty and have been offered a Rist horn to replace it. In view of the above, I think that I will look for an Altette or something that looks similar. Regards Graham
15-02-2024, 09:21 AM
Have you thought about restoring it? There is technical information available on the tinternet. I have restored mine as they are quite simple in design and how they work.
Good luck.
15-02-2024, 09:30 AM
15-02-2024, 11:31 AM
I have a misbehaving Altette taken off my February 1937 Ruby - it can work, but not reliably, so obviously needs some adjustment.
Following the above link for a little while, I arrived at this document: https://www.mg-tabc.org/library/Altette_Horn.pdf which looks useful.
15-02-2024, 11:46 AM
(This post was last modified: 15-02-2024, 02:28 PM by Reckless Rat.)
I have the original Rist Horn for my RP but I have swapped it for a modern 6v klaxon I bought on a French Classic accessory site. It is VERY loud! The Rist, by comparison, was a pathetic "croak" and more frustratingly only worked when it felt like it. The klaxon is operated by a push button on the dash, but I only use it for show.
The main horn is a 6v Lucas which a former colleague at work gave me - it came from a Panther 600 allegedly. It's also very effective. Looks like the Altette. sorry, posted the wrong image earlier |
