Car type: Ruby mk 2
My coil is showing a small oil leak on the top.
Coil is mounted vertically
Still using 6 volt electrics
Prices range from about £18 to £45
I like the look of a Remax advertised by Green Spark company
Any thoughts or recommendations
Regards
Tim
Someone may correct me if I am wrong but I seem to recall reading that the Remax of today is not the same as Remax of a few years ago.
John Mason
Car type: Ruby mk 2
From the little I found the Remax products were recently started to fill the often faulty products now in circulation
I would be tempted to continue using the leaking coil. As the oil level drops a bit it will soon stop leaking.
