Ruby ignition coil - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby ignition coil (/showthread.php?tid=9169) |
Ruby ignition coil - Tiger - 10-02-2024 My coil is showing a small oil leak on the top. Coil is mounted vertically Still using 6 volt electrics Prices range from about £18 to £45 I like the look of a Remax advertised by Green Spark company Any thoughts or recommendations Regards Tim RE: Ruby ignition coil - John Mason - 10-02-2024 Someone may correct me if I am wrong but I seem to recall reading that the Remax of today is not the same as Remax of a few years ago. John Mason RE: Ruby ignition coil - Tiger - 10-02-2024 From the little I found the Remax products were recently started to fill the often faulty products now in circulation RE: Ruby ignition coil - Hugh Barnes - 11-02-2024 If you can find one of these at 6v https://www.ebay.co.uk/itm/156033519181 I can highly recommend them. This one is too expensive, I think, I'd pay half that perhaps (but there again, I am frugal) but I have one on the Box that has been in place for the last 50 years and one on the Cabriolet that has been there for 25. Always a risk buying second hand, of course, so getting some guarantees would be helpful... They come up on Ebay pretty regularly... RE: Ruby ignition coil - andrew34ruby - 11-02-2024 I would be tempted to continue using the leaking coil. As the oil level drops a bit it will soon stop leaking. RE: Ruby ignition coil - Pearls not a Singer - 11-02-2024 See https://www.holden.co.uk/files/remax_coil_inside_2_1.pdf for the remax but I've also heard that failures are common, which is why the fussy air cooled VW boys go for genuine bosch as they have the reputation for not breaking. You may want to have a look at this https://simonbbc.com/Viper-Dry-Ignition-Coil-Sports-6-Volt-Acorn-Fit-BLACK |
