Ruby ARR Head light Dip Switch
Hi All,
Just starting to connect up the new wiring loom for my Ruby. On the dip switch it has three connectors but I do not know what wires go to what connector! Huh
the three wires are:
Blue
Red / Black
Blue /Yellow
Can some one Help.
Hi
The Blue is the common input to the switch. If you are using the commonplace Lucas 31284 floor mounted dip switch (as per Morris Minor etc) this goes to the terminal nearest one of the fixing bolts. It doesn't really matter which way round the other two go, as the switch just toggles from main to dip them main again etc.
It's rather unlikely, but if you have an original Austin dip switch (small diameter button) they aren't rated at sufficient current to drive headlamps directly, as they were used to drive a dipping relay.
Thanks John,
that helps and yes it is the standard Lucas dip switch.
