Ruby ARR Head light Dip Switch - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby ARR Head light Dip Switch (/showthread.php?tid=9101) |
Ruby ARR Head light Dip Switch - Timbo - 05-01-2024 Hi All, Just starting to connect up the new wiring loom for my Ruby. On the dip switch it has three connectors but I do not know what wires go to what connector! ![]() the three wires are: Blue Red / Black Blue /Yellow Can some one Help. RE: Ruby ARR Head light Dip Switch - John Cornforth - 05-01-2024 Hi The Blue is the common input to the switch. If you are using the commonplace Lucas 31284 floor mounted dip switch (as per Morris Minor etc) this goes to the terminal nearest one of the fixing bolts. It doesn't really matter which way round the other two go, as the switch just toggles from main to dip them main again etc. It's rather unlikely, but if you have an original Austin dip switch (small diameter button) they aren't rated at sufficient current to drive headlamps directly, as they were used to drive a dipping relay. RE: Ruby ARR Head light Dip Switch - Timbo - 05-01-2024 Thanks John, that helps and yes it is the standard Lucas dip switch. |
