Camshaft removal
Morning all
I'm doing an unhurried partial engine overhaul at the moment.  At some stage I want to take the camshaft out.  Assuming the block and tappets are out of the way, can I just unscrew the square headed camshaft bush locator and slide the camshaft out forwards without disturbing the oil pump ? The round disc above its gear is nicely sealed at the moment and I'd prefer to leave it be.
Having got the camshaft out and on the bench, what's the best way of getting the pinion off the end ?
Mine came off easily
Lightly clamped in copper covered vice jaws just behind the gear wheel.
Then hit the shaft with mallet ( nut released a few threads)
I did apply some heat via electric heat gun.
Hope this helps
Hope you are enjoying Christmas
Regards
Tim
All, as above, but using a tight puller, like the one below. One sharp tap is normally all that is required:
.png   Screenshot 2023-12-26 at 13.02.04.png (Size: 144.67 KB / Downloads: 139)
