Racing plugs?
I wonder if anyone in the A7 racing fraternity could recommend a good plug? I've been using the Champion D16 18mm as available from our cherished suppliers but have had a few failures.
I've got a set of 18mm-14mm adaptors so could change to a 14mm plug if that gives more options. The engine is fairly hot (blown 12psi).
Any suggestions very welcome Smile
The Champion D21 18mm plugs seem to work better than the D16s and are available from the Cherished Suppliers.
+1 for D21s.  They work well on my Special with a Ricardo head!
I've found the older style NGK A6's (not AB6) work well with my blown car.
Charles
