Racing plugs? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Racing plugs? (/showthread.php?tid=8847) |
Racing plugs? - Dirk73 - 30-08-2023 I wonder if anyone in the A7 racing fraternity could recommend a good plug? I've been using the Champion D16 18mm as available from our cherished suppliers but have had a few failures. I've got a set of 18mm-14mm adaptors so could change to a 14mm plug if that gives more options. The engine is fairly hot (blown 12psi). Any suggestions very welcome ![]() RE: Racing plugs? - David Cochrane - 30-08-2023 The Champion D21 18mm plugs seem to work better than the D16s and are available from the Cherished Suppliers. RE: Racing plugs? - Howard Wright - 31-08-2023 +1 for D21s. They work well on my Special with a Ricardo head! Cheers Howard RE: Racing plugs? - Charles P - 31-08-2023 I've found the older style NGK A6's (not AB6) work well with my blown car. Charles |
