Oil pipe flush
Hi guys is there way of flushing the internal oil pipe system without stripping the engine out
All the best austineers
Thank you very much for this question, because I have been thinking about this question for a long time. Although I change the oil regularly (each year after less than 1000 miles), I would like to use special oils that - according to the producer- flush the system within a few miles at low rpm. Will this help or harm?
One example of a potential cleaner can be found here (Wagner Öl).
Kind regards
Frank
Probably better posted in Forum Chat.
