Oil pipe flush - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Managment info box... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=17) +--- Forum: What's new or coming up... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: Oil pipe flush (/showthread.php?tid=8471) |
Oil pipe flush - stephen m thompson - 25-03-2023 Hi guys is there way of flushing the internal oil pipe system without stripping the engine out All the best austineers RE: Oil pipe flush - Frank Stoll - 09-05-2023 Thank you very much for this question, because I have been thinking about this question for a long time. Although I change the oil regularly (each year after less than 1000 miles), I would like to use special oils that - according to the producer- flush the system within a few miles at low rpm. Will this help or harm? One example of a potential cleaner can be found here (Wagner Öl). Kind regards Frank RE: Oil pipe flush - Tony Press - 10-05-2023 Probably better posted in Forum Chat. |
