  • 2 Vote(s) - 3 Average
Fuel Pump Spares Kit
I have a 1935 Ruby and I've just removed my fuel pump after 10 years use and stripped it down.
I know I can get a replacement diaphragm but I also want the two valves and valve gasket, the valves are the assembled type in a metal casing and the gasket that is a one piece like a figure "8"
I'll require the other gasket for the top and the crankcase but I can't find anywhere online that supplies a complete kit or the valves and their gasket.
Please can anyone point me in the right direction. Smile
Try Flexolite.co.uk you need to make sure you specify the correct AC pump, have bought from them in the past.
Holmsdale Sevens also rebuild fuel pumps
It sounds like your pump is a Model U; I can supply the valves and gaskets that you describe.
Thanks for the reply David, I've sent you an email with a list of parts please add to it if i've missed anything out.
