Fuel Pump Spares Kit - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Fuel Pump Spares Kit (/showthread.php?tid=8514) |
Fuel Pump Spares Kit - DaveT - 11-04-2023 I have a 1935 Ruby and I've just removed my fuel pump after 10 years use and stripped it down. I know I can get a replacement diaphragm but I also want the two valves and valve gasket, the valves are the assembled type in a metal casing and the gasket that is a one piece like a figure "8" I'll require the other gasket for the top and the crankcase but I can't find anywhere online that supplies a complete kit or the valves and their gasket. Please can anyone point me in the right direction. RE: Fuel Pump Spares Kit - Denis Sweeney - 11-04-2023 Try Flexolite.co.uk you need to make sure you specify the correct AC pump, have bought from them in the past. Holmsdale Sevens also rebuild fuel pumps RE: Fuel Pump Spares Kit - David Cochrane - 11-04-2023 It sounds like your pump is a Model U; I can supply the valves and gaskets that you describe. RE: Fuel Pump Spares Kit - DaveT - 12-04-2023 Thanks for the reply David, I've sent you an email with a list of parts please add to it if i've missed anything out. |
