Radiator repair
As I was working on the axels on the ruby I noticed that when i’d removed the radiator Ymir had left a stud behind. does anyone know Place in Hampshire that can repair the studs?
I repaired both studs on the Ruby
Used small metal plate with stud attached then araldite to radiator
Thanks. I was thinking about that technique.
I have several spare radiators in my stock pile but only the one has side panels. The rest are exposed cooling fins. Is that because they are from early ruby’s?
