Radiator repair - Printable Version
+--- Thread: Radiator repair (/showthread.php?tid=8355)
Radiator repair - Stephencrisp360 - 11-02-2023
As I was working on the axels on the ruby I noticed that when i’d removed the radiator Ymir had left a stud behind. does anyone know Place in Hampshire that can repair the studs?
RE: Radiator repair - Tiger - 12-02-2023
I repaired both studs on the Ruby
Used small metal plate with stud attached then araldite to radiator
RE: Radiator repair - Stephencrisp360 - 12-02-2023
Thanks. I was thinking about that technique.
I have several spare radiators in my stock pile but only the one has side panels. The rest are exposed cooling fins. Is that because they are from early ruby’s?
