19-08-2022, 09:25 PM
Just removed the outer hubs today and they appear to have been assembled with some form of loctite.
Is this usual practice with worn tapers or is this a good idea with good fitting ones.
Also, how can you check if the tapers have been lapped too much and the inner halfshaft gear is going to contact the diff cage without bolting it all up and seeing if it spins easily.
Many thanks.
Adrian.
Many thanks.
Adrian.
