06-08-2022, 01:01 PM
Does the starter motor switch/assy sit on top of the band that covers the commutator/brushes or should the band have a cutout to allow the switch to fit on the starter motor body ?
Starter Motor M35a
06-08-2022, 05:24 PM
Ok
Thanks David
08-08-2022, 06:29 PM
If you take the band off make sure you remove the switch as well.
The reason is that the band has a half moon cut out which fits around the copper contact on the starter motor. If the band is fitted incorrectly it can cause a dead short when you operate the starter switch. Refit the band making sure it is not touching the copper contact then re fit the switch.
08-08-2022, 06:33 PM
Yep
Understood |
