30-07-2022, 10:32 AM
Just my luck, I’ve stripped the clutch pedal pinch bolt, would any of you wonderful people be able to tell me what size it is please?
Clutch pedal pinch bolt size help!
30-07-2022, 11:01 AM
Pretty sure it's 5/16 bsf although I can't go and check.
If you check the quality/damage in the lever with an old head stud or similar,i.e. If it screws in easily you may or may not need to put a tap through it.
30-07-2022, 11:13 AM
Thanks Austin, I’ll have a measure up and see if I can find a head stud!
30-07-2022, 11:50 AM
Open workshop door, check clutch pedal lying on the bench: 5/16” BSF.
30-07-2022, 12:06 PM
Brilliant, thanks Steve!
