Battery - again
Had anyone had experience of this.
Against this:
I always use Alpha's 421s - never had a problem with either delivery or reliability.
Rick
In deepest Norfolk
And one more.
Regular charging extends the life of Lead Acid batteries. Easy to let this slide in winter months.
Yes, but one is lead acid and the other gel and sealed. ,,possibly.
You pay more one is called 'classic'.
I should have said classic hard rubber'
They both look like lead acid to me !
There was a classic hard rubber battery on my A7 when I bought it - see this thread. It was certainly sturdy but the starting performance wasn't great. The "Lucas" one in your top picture is only rated 57Ah. I assume they are intended for sporting applications, such as trials and hill climbs, where shock resistance is more important than cold starting.
The £90 "Ultra Plus" in your bottom picture is 77Ah and 550cca so will be much better on cold mornings. I went with the genuine Exide EU80-6, which is 80AH and 600cca. I notice Batteries and Solar currently lists it at £83 (although it's out of stock!)
Thank you all, thank you Ian,
Bought the ultra eventually.
Joe
