Battery - again - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Battery - again (/showthread.php?tid=7652) |
Battery - again - joe - 23-06-2022 Had anyone had experience of this. Against this: RE: Battery - again - Rick F - 23-06-2022 I always use Alpha's 421s - never had a problem with either delivery or reliability. RE: Battery - again - Steve kay - 23-06-2022 And one more. RE: Battery - again - bob46320 - 23-06-2022 Regular charging extends the life of Lead Acid batteries. Easy to let this slide in winter months. RE: Battery - again - joe - 23-06-2022 Yes, but one is lead acid and the other gel and sealed. ,,possibly. RE: Battery - again - Bill Dixon - 23-06-2022 You pay more one is called 'classic'. I should have said classic hard rubber' RE: Battery - again - Tiger - 24-06-2022 They both look like lead acid to me ! RE: Battery - again - Ian Wegg - 24-06-2022 There was a classic hard rubber battery on my A7 when I bought it - see this thread. It was certainly sturdy but the starting performance wasn't great. The "Lucas" one in your top picture is only rated 57Ah. I assume they are intended for sporting applications, such as trials and hill climbs, where shock resistance is more important than cold starting. The £90 "Ultra Plus" in your bottom picture is 77Ah and 550cca so will be much better on cold mornings. I went with the genuine Exide EU80-6, which is 80AH and 600cca. I notice Batteries and Solar currently lists it at £83 (although it's out of stock!) RE: Battery - again - joe - 24-06-2022 Thank you all, thank you Ian, Bought the ultra eventually. Joe |
