Battery - again
23-06-2022, 07:17 PM
I always use Alpha's 421s - never had a problem with either delivery or reliability.
Rick
In deepest Norfolk
23-06-2022, 08:13 PM
And one more.
23-06-2022, 08:43 PM
Regular charging extends the life of Lead Acid batteries. Easy to let this slide in winter months.
23-06-2022, 09:27 PM
Yes, but one is lead acid and the other gel and sealed. ,,possibly.
23-06-2022, 09:43 PM
(This post was last modified: 23-06-2022, 09:46 PM by Bill Dixon.)
You pay more one is called 'classic'.
I should have said classic hard rubber'
24-06-2022, 04:50 AM
They both look like lead acid to me !
There was a classic hard rubber battery on my A7 when I bought it - see this thread. It was certainly sturdy but the starting performance wasn't great. The "Lucas" one in your top picture is only rated 57Ah. I assume they are intended for sporting applications, such as trials and hill climbs, where shock resistance is more important than cold starting.
The £90 "Ultra Plus" in your bottom picture is 77Ah and 550cca so will be much better on cold mornings. I went with the genuine Exide EU80-6, which is 80AH and 600cca. I notice Batteries and Solar currently lists it at £83 (although it's out of stock!)
24-06-2022, 11:38 AM
Thank you all, thank you Ian,
Bought the ultra eventually. Joe |
