New member
Thank you for adding me to the forum.
My son and I have recently bought an Austin 7 Ruby which needs putting together. My friend started the project 19 years ago and has done almost everything apart from re assembling it.
We have lots of questions so we have joined our local Austin Seven Owners Club. I’m sure many of the answers will be on here already too.
That looks like a mk 1 Ruby, from about 1935? Not that Austin called them mk 1 and mk 2.
Welcome to the forum, look forward to seeing you both again at the Sun Inn next month
Denis #
(31-03-2022, 05:51 PM)andrew34ruby Wrote: That looks like a mk 1 Ruby, from about 1935? Not that Austin called them mk 1 and mk 2.
Yes it is a MK 1 from 1935
(31-03-2022, 07:41 PM)Denis Sweeney Wrote: Welcome to the forum, look forward to seeing you both again at the Sun Inn next month
Denis #
Thanks Denis, I have a few questions to ask at the next meeting if you are there. As I didn’t take the car apart it is hard to know how to re assemble it but good fun finding out.
Great to see another 7 rescued
We took a similar project on a few years ago but ours is a 1936 Ruby.
We have experienced a massive amount of help from the forum.
I see you are roofless at the moment not sure which parts you have however as you probably know almost all parts are available.
I found most problems solved by posting pictures and a brief explanation
Regards
Tim
PS Good luck !
Hi s.earl
Looks like a nice early Ruby.
Glad to see you are upholding the tradition of having a threadbare pre 1960 MOT style tyre to push the chassis around on !
If you haven't already got a copy, the spare parts list will help with identifying things: http://archive.a7ca.org/wp-content/uploads/PL_1218A.pdf
There is also a body parts list, only for the later Ruby but could still be of use: http://archive.a7ca.org/wp-content/uploads/PL_1521.pdf
(02-04-2022, 05:43 AM)Tiger Wrote: Great to see another 7 rescued
Regards
Tim
PS Good luck !
Thank you, I’m sure we will have a few questions as we didn’t dismantle the car. The sliding roof makes no sense to me yet but I’m told that I have all the parts.
(02-04-2022, 09:45 AM)John Cornforth Wrote: Hi s.earl
Thanks for those lists! Very helpful information.
I now know that the 2 random pieces that I couldn’t work out are called flitch plates after looking at the body parts book.
Here the bit you mentioned in place !!!
