New member - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: New member (/showthread.php?tid=7345) |
New member - s.earl - 31-03-2022 Thank you for adding me to the forum. My son and I have recently bought an Austin 7 Ruby which needs putting together. My friend started the project 19 years ago and has done almost everything apart from re assembling it. We have lots of questions so we have joined our local Austin Seven Owners Club. I’m sure many of the answers will be on here already too. RE: New member - andrew34ruby - 31-03-2022 That looks like a mk 1 Ruby, from about 1935? Not that Austin called them mk 1 and mk 2. RE: New member - Denis Sweeney - 31-03-2022 Welcome to the forum, look forward to seeing you both again at the Sun Inn next month Denis # RE: New member - s.earl - 01-04-2022 (31-03-2022, 05:51 PM)andrew34ruby Wrote: That looks like a mk 1 Ruby, from about 1935? Not that Austin called them mk 1 and mk 2. Yes it is a MK 1 from 1935 (31-03-2022, 07:41 PM)Denis Sweeney Wrote: Welcome to the forum, look forward to seeing you both again at the Sun Inn next monthThanks Denis, I have a few questions to ask at the next meeting if you are there. As I didn’t take the car apart it is hard to know how to re assemble it but good fun finding out. RE: New member - Tiger - 02-04-2022 Great to see another 7 rescued We took a similar project on a few years ago but ours is a 1936 Ruby. We have experienced a massive amount of help from the forum. I see you are roofless at the moment not sure which parts you have however as you probably know almost all parts are available. I found most problems solved by posting pictures and a brief explanation Regards Tim PS Good luck ! RE: New member - John Cornforth - 02-04-2022 Hi s.earl Looks like a nice early Ruby. Glad to see you are upholding the tradition of having a threadbare pre 1960 MOT style tyre to push the chassis around on ! If you haven't already got a copy, the spare parts list will help with identifying things: http://archive.a7ca.org/wp-content/uploads/PL_1218A.pdf There is also a body parts list, only for the later Ruby but could still be of use: http://archive.a7ca.org/wp-content/uploads/PL_1521.pdf RE: New member - s.earl - 04-04-2022 (02-04-2022, 05:43 AM)Tiger Wrote: Great to see another 7 rescued Thank you, I’m sure we will have a few questions as we didn’t dismantle the car. The sliding roof makes no sense to me yet but I’m told that I have all the parts. (02-04-2022, 09:45 AM)John Cornforth Wrote: Hi s.earl Thanks for those lists! Very helpful information. I now know that the 2 random pieces that I couldn’t work out are called flitch plates after looking at the body parts book. RE: New member - flywheel1935 - 04-04-2022 Here the bit you mentioned in place !!! |
