01-04-2022, 04:35 PM
Hi all. I need to remove the N-S. Door on our ruby, but I am having trouble trying to knock the hinge pins out. Are they peened over? I do not want to use heat as the paint is in good order, also I do not want to remove the door by removing the bolts/screws from the wood frame. (But I may have to) The three brass screws that are on the bottom hinge will need an impacted screw driver to remove them, but the metal around the base screws look very weak/rusty, that’s why I need to remove the door, any ideas please Also is it possible to purchase new hinge pins. Sorry for my meandering .S&P.
