29-03-2022, 03:09 AM
i have a 1/1/4 in carb for my austin 7 what size jets do i need cheers
cu carb
29-03-2022, 06:54 AM
You will need to provide a lot more information to obtain and answer which is relevant to your situation, if you have a standard unmodified engine the carb you have is too big and will never provide optimum performance.
29-03-2022, 08:08 AM
(29-03-2022, 06:54 AM)Ian Williams Wrote: You will need to provide a lot more information to obtain and answer which is relevant to your situation, if you have a standard unmodified engine the carb you have is too big and will never provide optimum performance. If your engine is moderately tuned you could start with a no.6 needle and blue spring. It may be on the rich side but it’s what I use and seems to give a good performance.
29-03-2022, 09:43 PM
CU ? SU ?
