cu carb - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: cu carb (/showthread.php?tid=7332) |
cu carb - bruce legg - 29-03-2022 i have a 1/1/4 in carb for my austin 7 what size jets do i need cheers RE: cu carb - Ian Williams - 29-03-2022 You will need to provide a lot more information to obtain and answer which is relevant to your situation, if you have a standard unmodified engine the carb you have is too big and will never provide optimum performance. RE: cu carb - Charles Levien - 29-03-2022 (29-03-2022, 06:54 AM)Ian Williams Wrote: You will need to provide a lot more information to obtain and answer which is relevant to your situation, if you have a standard unmodified engine the carb you have is too big and will never provide optimum performance. If your engine is moderately tuned you could start with a no.6 needle and blue spring. It may be on the rich side but it’s what I use and seems to give a good performance. RE: cu carb - Tony Press - 29-03-2022 CU ? SU ? |
