31/32 rear axle oil seal
Hi All
I have a 31/32 rear axle where the torque tube to banjo joint includes shims to get the CW&P mesh correct.
There is no mention in Woodrow about how to seal this joint.  I put it together with just the shims and no gasket goo, however I’m now getting a very small oil leak from the joint.
What do others use to seal this joint?  I’m a little concerned that any sealant may throw the mesh out.
I doubt that it's a problem. Perhaps slightly less oil in the axle would prevent it. The specified quantity is over-generous.
It stops the diff housing rusting. Can smear Si around the assembled joint.
