Type 65 / Nippy Cylinder Head Gasket
#21
(03-03-2018, 09:56 AM)Ian Williams Wrote: "I'd be interested to know what the perceived benefits are of the solid copper gasket (apart from the fact it can be reused after annealing)."
Better mechanical strength, and better heat transfer, a bugger to seal the water ways though!
Ian, I am getting one of your gaskets from Martin Baker and proposing to assemble with a smear of grease on both sides. Knowing that sealing the waterways is a bugger is interesting, but not quite so much as knowing how you resolved the issue would be. Any chance of some enlightenment?
Martin had some of the copper asbestos gaskets which are basically the same as those available in the UK but to sports pattern. I was referring to solid copper being a bugger to seal, but that said the modern C/A gaskets can be a pain too, Hylomar spray seems to be the best solution to the problem that I have used, others may have their own solution
(22-02-2018, 06:54 PM)Colin Wilks Wrote: [quote pid='7350' dateline='1519319797']
I think you're right John, but I understand those for the 65 and Nippy are different to the later h/c gakets. Be interesting to know if anyone has used the 36 to 39 high compression gasket in a 1934 Type 65 without problems. I thought the intrusion of these gaskets into the combustion chamber lead to pre ignition, but I may be making that up?
[/quote]
Coming back to this comment about gasket protrusion into the combustion chamber causing pre-ignition.
It is my understanding the cylinder head temperature during running can reach a maximum of around 400 C at which temperature copper can possibly glow a dull red.
I wouldn't think this could cause pre-ignition, so a miss shaped gasket is not a major problem as long as it seals both water and combustion.
Any comments ?
Cheers, Tony.
Film of a demonstration of ignition temperatures from 1948: https://youtu.be/yG0rP3D_0-s
Other sources quote the ignition temperature of a flammable mixture of petrol and air (1.4 to 7.6%) in a range between 230 and 280°C (https://hypertextbook.com/facts/2003/Sha...pher.shtml)
(12-03-2018, 10:26 AM)Colin Wilks Wrote: Film of a demonstration of ignition temperatures from 1948: https://youtu.be/yG0rP3D_0-s
With the suggested C temperatures below I would think that some other parts of the combustion chamber could 'spark' auto ignition then (or am I totally confused) ?
  1. Intake manifold : 60
  2. Intake valve : 250
  3. Spark plug : 600
  4. Exhaust valve : 650
  5. Exhaust gases : 450
  6. Piston face : 300
  7. Cylinder wall : 185
  8. Piston ring : 220
  9. Piston skirt : 190
  10. Coolant : 105
  11. Engine oil : 70
  3. Spark plug : 600
  10. Coolant : 105
  11. Engine oil : 70
If you accept the assertion in the article's last paragraph "[color=rgba(0, 0, 0, 0.92)]The flammability range of gasoline is between 1.4 and 7.6%. If the ratio of gasoline to air is less than 1.4%, then the mixture is to thin to burn. The mixture cannot burn when it contains more than 7.6% gasoline because it is too rich to burn." then perhaps it is only when the charge has started to be compressed that it falls within the flammability range?[/color]
