Car type: Type 65 1934 + RP 1932
I have been told these are not being made by anybody. I'd like to get one for my 1934 Type 65. Before I start looking at getting a bespoke one made up locally here in Yorkshire, please does anyone know if they are off the shelf anywhere?
The ones for the later h/c heads (36 onwards) are available but I think I have read on here that these are a different shape and protrude into the combustion chamber?
Many thanks for any advice.
Colin
Colin I think most if not all cherished suppliers stock both high and low compression gaskets.
Yours John Mason
Colin. Is there any way you could let me know who made the gaskets for your friend? I need a couple of gaskets made for a Morris. Thanks.
If more sports gaskets are wanted I could get another batch made but I will need a confirmed order for at least 10, I could also get gaskets made in solid copper if there is any interest HC, LC or Sports pattern, again minimum 10. Price guide on the last lot was in the region of 30 pounds for a CA Sports and about 45 pounds for a solid copper, if there is enough genuine interest I can get up to date prices, and it would probably be best if someone in the UK acted as distributer to keep postage costs down.
NB, I do not do this commercially, simply to help fellow enthusiasts!
That's a result. Thanks Nick. See you in Batley!
Hi
I bought some special gaskets made in NZ last year and have some left if you'd like one.
The price is £27.50 each plus postage (~£4.50).
I've still got six high compression and one low compression (supercharged Ulster) left.
Hope this helps.
Martin
