11-03-2018, 02:13 PM
(03-03-2018, 09:56 AM)Ian Williams Wrote: "I'd be interested to know what the perceived benefits are of the solid copper gasket (apart from the fact it can be reused after annealing)."
Better mechanical strength, and better heat transfer, a bugger to seal the water ways though!
Ian, I am getting one of your gaskets from Martin Baker and proposing to assemble with a smear of grease on both sides. Knowing that sealing the waterways is a bugger is interesting, but not quite so much as knowing how you resolved the issue would be. Any chance of some enlightenment?
